Problem resetting count on read with fp ctr-500 counter
Using the ctr-500 module with a FP-1000.  I want to reset the count of a channel on each read.  The CTR-500 manual says to selecting "Reset on Read" from the Value menu.  I've done that but the counter never resets when I read it.  I then tried clicking on "Creat item" under channel attributes in MAX.  It creates an item called "Read Reset Mode @Count Input 0" under Data Neighborhood.  Added that item to the program and wrote to it with both a 1 and 0,  but when I read channel 0 it still will not reset. Obviously, I'm missing something. I would appreciate any help or a simple example so I can get this resolved.  Thanks, Mike
Message Edited by mike72903 on 01-31-2008 10:51 AM
(2,350 Views)
Found an example.  Thanks anywaySmiley Wink
(2,333 Views)
