Problem running FrontPanelStates.vi example
'm trying to run the example VI "FrontPanelStates.vi".  When I do, I get the following error message:
    Error 15 occurred at Open VI Reference in FrontPanelStates.vi
    LabVIEW:  Resource not found.
    NI-488:  Serial poll byte queue overflow.
    An error occurred loading VI 'runvi.llb'.
    LabVIEW load error code 8: Could not load VI resource.
I don't have 488 in the system.  Does this example use it in some fashion?
I'm really trying to debug the procedure for loading a VI front panel into a subpanel, and be able to change the displayed data.  Could this problem be interfering with that?  Can anyone offer suggestions for this the "real" problem?
Thanks for any help.
___________________
Dennis Knight responded:
You did not notice the Possible Reason(s) part? That means that the error code can have a couple of causes - depending on where it occurs. Since you are not using GPIB and are using LabVIEW, then the first reason would apply. When you ran it, did you pick a valid VI or did you try to select a different type of file such as an llb?
____________________
I tried to load a vi from the same llb that contained FrontPanelStates.vi.
Tom J
(3,395 Views)
Pick a VI that's not in an llb and see if that makes a difference.
(3,389 Views)
