Problem running two parallel while loops
It works!! Thanks everyone, especially billko, johnsold and RavensFan . I have learnt a lot through this exercise.
I am attaching the final program, so that it may help others
Avinash
Message 91 of 95
(1,384 Views)
Avinash
You used the forum exactly the way it should be used.  Get some ideas, some advice, try it out and come back with your new version.  Too many people just hope you write the code for them.  🙂
Bill
CLD
(Mid-Level minion.)
Message 92 of 95
(1,374 Views)
Final version of my code modified to work with both scales simultaneously taking readings at 10second intervals.
-Avi0111
Message 93 of 95
(1,366 Views)
Not bad for someone just starting down the LabVIEW path.  🙂  Check out this tutorial to learn how to clean up and optimize your code.  🙂
Bill
CLD
(Mid-Level minion.)
Message 94 of 95
(1,361 Views)
Thank you Bill.
Message 95 of 95
(1,355 Views)
