Problem solved (partly)
I had the same problem and solved it by writing my own routine to allow
multiple selection. It`s not a windows native progress, so some selection
mechanisms are different, but you can have it if you want. The vi outputs
an array of paths.
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,762 Views)
I would like a copy of the VIs, if you don't mind. Please send files to: jkring(@)calbay(.)com - remove parentheses
Thanks, Jim
(2,762 Views)
