Problem to detect an USB device
I'm facing an issue with detecting a device. Specifically, I'm trying to detect which USB port my oscilloscope is connected to, but depending on the order in which the device is connected and LabVIEW is launched, it becomes impossible.
If I connect the oscilloscope first and then launch LabVIEW, my VI correctly detects the USB port where the oscilloscope is connected. However, if I connect my oscilloscope after launching LabVIEW, my VI does not detect the port and generates an error (Error code: -1073807360, VISA Write in "Test USB device.vi").
I’ve attached my VI and a screenshot of my block diagram. Any help would be greatly appreciated.
Thank you.
Djamel
(877 Views)
If the USB scope has the same "alias" everytime you connect it, you can create a subvi to verify if the instrument is connected, and give  a message to the operator.
You can also test while the labview vi is still running connect the scope and verifh that labview finds the instrument.
(854 Views)
