Problem using a case structure selector controlled by a cluster of enums
I have attached a couple of files to get input from the gurus of LV.  My problem is that I can't get data from the lower 5 enums from my DAQ vi.  I'll do my best to explain.
In the DAQ.vi program, the selector for the case structure is controlled by a cluster of enums that originates in the IO.vi (see the .jpg file IO.jpg)  The 9 enums control the DAQ acquisition.  When I run the DAQ.vi, I can manually select the different enums (from the DAQ.vi front panel called DAQ signal) and I see the data for each case...P1 through Rad6.  This works great.  However, when I run the IO.vi, I only can see the first 4 data values in the Data Out cluster.  Rad1 - Rad6 are NaN.  For some reason, the enum cluster P1 - Rad6, in the IO.vi is not selecting all of the 9 enums...just P1 - T.  Can an enum cluster be used as a selector??  I can't seem to figure out why only the first 4 enums are displaying data but the others below them are not?  Hopefully someone knows whats going on.
ProDev
Message 1 of 16
(4,704 Views)
It would have helped if you had posted the main VI as well. What are the sizes of all of the other arrays? You've got a number wired to the 'N' terminal of the for loop but you also auto-index all of the input arrays. You nornally do one or the other. The for loop will only iterate for a count equal to the size of the smallest array. So if the smallest array has only 2 elements, the for loop will only run for two iterations.
Message 2 of 16
(4,685 Views)
Do  all of you input arrays to the for loop have enough elements?
Ben
Message 3 of 16
(4,682 Views)
Thanks Dennis for the reply,
I put the number to the N terminal as I was troubleshooting the problem and forgot to remove it.  I have posted the IO.vi.  This vi will run and acquire data.  Where is the smallest array in this vi... the 9 enum constants?  I want to auto-index the input arrays but I'm not sure this is what I am doing.
Message 4 of 16
(4,679 Views)
Ben,
Yes, each enum has all 9 elements and I add an element in the enum cluster then chose the proper element.
Message 5 of 16
(4,678 Views)
If you want someone to look at a VI, you need to remove the password protection. I can tell that you don't have all of your arrays the same size. The cal factors array only has 6 rows. When you have multiple arrays auto-indexed, it is the size of the smallest array that determines how many times the for loop iterates. On the image you posted, you have 4 arrays going into the for loop. I can't see 2 of thme on the actual front panel but my guess is that one of them only has 2 elements.
Message 6 of 16
(4,669 Views)
My apologies Dennis,
I tried to remove the password but it told me I couldn't leave it blank.  I'm still learning 😛   The password is io  lowercase just like the VI's name.
Thank you again!!
Message 7 of 16
(4,659 Views)
As I said, the cal factors array on your front panel only has 6 rows so the for loop will only run 6 times. When I ran your program, this is exactly what I saw. Place an indicator on the 'i' terminal and see what it says when you run the program. I was missing a lot of subVIs so all I could do was run the for loop. If you have data missing, maybe it's happening later in the program.
Message 8 of 16
(4,646 Views)
Awesome, that worked.  I increased the array size of Cal Factors  to 10 elements and now I get all of th data EXCEPT the last one...Rad6. I have checked all of the other arrays going into the For loop and they all are 10 elements or more (I think). I've setup a wire value indicator while the for loop is running and it only goes to Rad5.  The for loop is the source of the problem. What am I overlooking?
Boy, if my wife heard some of he words coming out of my mouth during this she'd have me sleeping with the dogs.
No password this time.
Thanks Dennis!!!
Message 9 of 16
(4,614 Views)
The VI you just posted still has only 6 rows in the CalFactors array. When you added the data, did you go to Edit>Make Current Values Default and then save the VI?
Message 10 of 16
(4,606 Views)
