Problem using read from spreadsheet file and polar plotting
Hi to all labview users,
i am a beginner in labview and i am trying to do a polar plot.
i read the polar plotting example in labview and it was straightforward.
I used "write to spreadsheet file" to gather data.
and they are in the following format
13  10
4  20
8 30
....etc
now. i tried using "read from spreadfile" to get the data into a array, then using "array to cluster" to convert the array into cluster, so i could connect it to the polar plot block
however, it kept saying i couldnt connect that way, because polar plot uses 1-d array with cluster of 2 element and my source is a cluster of 9 elements....
but doesnt the "read from spreadfile" block give me a 1-d array? and where does that 9 come from? i only have 3 rows and 2 columns in my data file....
any guidance would be greatly appreciated.
thx alot
Happy guy
~ currently final year undergraduate in Electrical Engr. Graduating soon! Yes!
~ currently looking for jobs : any position related to engineering, labview, programming, tech support would be great.
~ humber learner of LabVIEW lvl: beginner-intermediate
(2,794 Views)
Helllo,
I've made an example to try to help you  with that question.
Notes:
 - the file must have values separeted by tab
 - reading the values from file as you mentioned using "read from spreadfile" you'll get a 2D array and not 1D;
Software developer
www.mcm-electronics.com
PORTUGAL
(2,788 Views)
