Problem w/ the Excel-TDM add-in
Hi-
I've used the ExcelTDM add-in on other machines w/ no problems, but I tried downloading it to a new computer (w/ office 2003, Vista) & the icons don't appear in excel.
I tried to follow the directions on this page:  http://zone.ni.com/devzone/cda/tut/p/id/5874
I get stuck at step #3 b/c the ExcelTDM.dll file is no where on the computer.  Is it possible that the add-in isn't downloading properly?  I've tried uninstalling and re-installing the add-in twice now, with the same results.
Any halp would be appreciated!  Thanks!!!
Erin
(4,641 Views)
Accepted by topic author ErinH
Hi ErinH,
We'd like to confirm that you get the latest web download installer from http://zone.ni.com/devzone/cda/epd/p/id/2944 first.
Then you can notice at the bottom of the dowload page there's one tip:
After the installation of the TDM Excel Add-In on Microsoft Vista you need to start Microsoft Excel at least once using administrator privileges.
So if you are using the Add-In in Vista, you can either turn off the UAC(User Account Control), or right click Excel.exe and "run As Administrator" for the first time.
Good luck!
(4,580 Views)
Thanks ykdoubles!  This worked!!!!
(4,517 Views)
