Problem when simulating an 8051 MCU in Multisim?
I faced a problem when simulating a simple 8051 MCU circuit (blinking a LED)
The C-code is compiled successfully but when it is not linked.
Here is what is displayed in the result barre:
Multisim - Tuesday, December 13, 2016, 2:13:58 AM
--------------------------Building: Project: project1---------------------------
Note: -E compiler option was not present. This option has been added to the compiler build command temporarily.
Note: -O compiler option was not present. This option has been added to the compiler build command temporarily.
Warning: -G compiler option was not present. This option has been added to the compiler build command temporarily.
Warning: --ASMLIST compiler option was not present. This option has been added to the compiler build command temporarily.
Warning: -P compiler option was not present. The assembler files will not be preprocessed for #include directives.
Warning: The --ERRFORMAT compiler option was not present. This option has been added to the compiler build command temporarily.
Warning: The --WARNFORMAT compiler option was not present. This option has been added to the compiler build command temporarily.
Warning: The --MSGFORMAT compiler option was not present. This option has been added to the compiler build command temporarily.
Compiler results: 0 - Errors, 0 - Warnings
Linking...
Unable to find object file: D:\My Folder\Studies\Multisim\MCU Workspaces\MCU\project1\main_0.obj
Please help me!
thanks 😉
(5,021 Views)
Hello el_maestro
What is the Multisim version are you running (Go to Help>>about Multisim)?
Did you use the tutorial below?
http://www.ni.com/tutorial/5629/en/  (Microcontroller Unit Co-Simulation)
Regards
(4,955 Views)
Hi David and thanks for replying me 🙂
The application version is: 14.0.0 (14.0.593)
Database version: 14.0.a
I followed the stapes one-by-one but it is the same. Also, when creating the project there is no Assembler Project file *.asm
Thanks!
(4,949 Views)
Hello el_maestro
Let me share with you a link forum where you can find and ask question of the MCU specifically. Feel free to participate there.
https://forums.ni.com/t5/Archive-TKB/NI-Multisim-Microchip-MCU-Co-Simulation-Beta/ta-p/3507206 (Forum)
Regards
(4,914 Views)
