Problem when use "saveas" function in MathScript Node, Can't save the figure ploted.
I want to save figure plot by MathScript Node, the function I used was "saveas". I could achieve my attention in matlab using this function. Where was the problem?
If this function is unusable in labview, how can I save the figure ploted using MathScript?
The following is the code I used in the MathScript Node:
x=1:0.1:10;
y=x.^2;
h=plot(x,y);
saveas(h,'G:\test2.jpg')
Thanks for any reply!
YangAfreet
(2,795 Views)
Please go to http://zone.ni.com/reference/en-XX/help/371361B-01/lvtextmath/msfunc_classes/ and see if "saveas" is an available function in LabVIEW MathScript. As a matter of fact,I do not see the need to complete the file I/O inside the MathScript node,Why do you want to do that?
(2,772 Views)
