Problem while communicating with ECU through NI USB CAN
Hello sir,
I want to communicate with ECU through NI USB CAN interface while i tried to communicate with ECU it gives timeout error. here i am using CCP version 1.0, ECU toolkit 2.1.4 and NI CAN 2.7.2 .if you have any problem that communicates with ECU using CCP version 1.0 Please attach it.
Thanks and Regards,
Madhan
(2,722 Views)
So for the fifth time you start a new thread about the same problem!
If you don't get any response to your threads, it could be because you are not giving a lot information about your problem.You could start with giving the vi you have problem with, so that we can see what you are doing.
You also need to give any error code and a description on that you have done, in details!
You also had one response in one of the other threads, it is polite to make an answer when someone is replying to you.
madhankumarlv@gmail.com wrote:
Hello sir,
Thanks and Regards,
Madhan
That makes no sense, where have you copied that from ?
(2,712 Views)
