Problem while communicating with NI CAN
Hello sir,
I am facing the error ERROR -301058 Ecu, when Iam trying to read the ccp variables using NI CAN (USB 8473).
The VI looks exactly same like yours.
So Did you find any solution how to read the data for the CCP variables using NI CAN.
If you have any vi which can communicate with NI CAN please attach it.
Thanks in Advance.
Madhan.
(2,985 Views)
HI Madhan,
Are you using the example vi? if not which vi you are refering to?
you may find the example file  " Transmit Receive same port.vi" useful.
---------------- Be Good. Do Good. ---------------------
(2,976 Views)
