Problem while using SIMATIC OPC Server
I have a project using Siemens SIMATIC_NET_PC_Software_V16 Software to create an opc server to connect s7-400H redundant type PLC using Labview DataSocket. There are double PLCs and PC need to connect to the PLCs at the same time. I found that the Siemens SIMATIC_NET_PC_Software_V16 Software can realize this requirement but with a trickier problem that when I run the VI, some controls (with DataSocket URL, the type is 'Publish' or 'Publish & Subscribe' ) turn to zero, and the relevant variables in PLC turn to zero too.
Is there any way to solve this problem.
About the Simens OPC server. I use STEP7 create the XDB files and import the file into the Simens Station Configurator.
I am an engineer from China and forgive my poor English.
Thanks.
Message 1 of 1
(1,424 Views)
