Problem with 3D picture in Labview
hello everybody ... please i have problem when i try to create 3D picture in front panel
I got this error and LabVIEW close after that
I have LabVIEW 2016 full and i installed openGL Extensions viewer
Message 1 of 9
(5,812 Views)
Are you able to open and run the Solar System example that ships with Labview?
aputman
Message 2 of 9
(5,800 Views)
thank you for reply ... i can't open anything related with 3D picture if i try to open it i got the same problem above
Message 3 of 9
(5,795 Views)
Make sure your video drivers are up-to-date, since that control relies heavily on OpenGL.  Are you using a laptop or a PC?  Do you have dedicated graphics card (Nvida, etc) or do you have an on-board video controller (Intel, etc)?
aputman
Message 4 of 9
(5,788 Views)
i am using Laptop and my card Intel you can see here and also i installed all new update
Message 5 of 9
(5,738 Views)
Accepted by topic author laith_Ismail
i solved this problem its related with power option
thank you very much
Message 6 of 9
(5,725 Views)
Please provide more detail so it can help others in the future if they search for the same problem and find your message.  What do you meany by "power option"?
Message 7 of 9
(5,667 Views)
sorry for that i forgot to show how can we solve this problem .... this video will explain how to solve this problem by changing the power options
https://www.youtube.com/watch?v=fJXPXgEXvcU
Message 8 of 9
(5,638 Views)
That makes sense for a laptop.  Thanks for sharing your solution.
You might want to write up a response explaining where you found the settings, just in case the video is removed.  Broken links are not helpful.  Smiley Happy
aputman
Message 9 of 9
(5,627 Views)
