Problem with 8164A drivers
I'm controling a 8164A (Agilent) via GPIB-USB controler. I can send simple GPIB messages to the instrument but I can use correctly the VI release by Agilent to execute fast scanning.
Is there somebody who can help me ?
Tosty
(3,024 Views)
Hi
Can you precise a little bit your request?
Do you have problems to use Agilent VI provided for the instrument?
What happens using the VISA test Panel to send message to your instrument?
Kamal
NIF
(3,011 Views)
I was able to send request to the instrument, but the agilent VI provided for the instrument (hp816xx) did worked.
I have solved the problem since I have updaded the Instrument firmware (from V2 to V4.51).
Thank you,
Tosty
(3,000 Views)
