Problem with Agilent 53132a LabVIEW Library
Hello All,
I am working with LabVIEW 8,5 and Agilent 53132a (Universal Counter).
I downloaded it and placed it in Program files/National Instrument/Inst Lib
but i restart LabVIEW platform, it is not showing Agilent 53132a Drivers in functions>>instrument lib
Please let me know what is exact problem i am facing with.
Best Regards
Puneet Kapoor
Message 1 of 16
(6,512 Views)
Hai,
am also facing same problem. someone could help soon.
Mathan
Message Edited by mathan on 05-15-2008 04:25 AM
Message 2 of 16
(6,502 Views)
Hii
Yes i am facing same problem.
If you are in hurry to use it, fetch required subvi from installed drivers(as in instrlib>>folder Aglient 53132a exists).
Puneet
Message 3 of 16
(6,491 Views)
Hey guys,
What you can do is to mass-compile the drivers with LabVIEW 8.5, then restart LabVIEW. There are more details that can be found here. Let us know how it goes!
Rasheel
Message 4 of 16
(6,466 Views)
But the link you shown was like this.
Message 5 of 16
(6,443 Views)
The issue is in LabVIEW 8.5 where the project-style drivers will not show up on the palette unless they are mass compiled in LabVIEW 8.5 version. This issue has been fixed in LabVIEW 8.5.1.
Message 6 of 16
(6,423 Views)
Hi mathan,
I apologize for the wrong link. The information I was speaking of can be found here. You will basically want to mass-compile the new folder in instr.lib. Let us know how it goes!
Rasheel
Message 7 of 16
(6,411 Views)
Hai rasheel,
I have one llb with version 6.0.5. Am using 8.5.
I did a mass compile as per your link.
But it says as like in the attachment.
Mathan
Message 8 of 16
(6,404 Views)
This is that LLB
Message 9 of 16
(6,403 Views)
As already explained here, if a VI has no block diagram, it cannot be loaded in a newer version of LabVIEW. LabVIEW needs the source code (block diagram) to recompile the VI.
Message 10 of 16
(6,398 Views)
