Problem with Call Library Function. Want to pass a string and return a string, but my compiler does not recognize "CStr" and Labview does not recognize my "char *function()" callout
Hi, I'm trying to use a .DLL I wrote in Visual C++ .NET. The Call Library Function generates a function prototype of "CStr Parser(CStr arg_raw)"
but my compiler won't accept this. So I change it to how C normally deals with strings "char *Parser(char *arg_raw). Now the Call Librafy Function does not find "Parser" in my .DLL though it is definitely there!
Help!
-Fong
(3,070 Views)
Hello
You will need to include extcode.h in your C file. You can find this under ..\LabVIEW\cintools folder.
The include has all the defines you will need.
Bilal Durrani
NI
Bilal Durrani
NI
(3,070 Views)
Hm, I don't have this folder in my directory. I'm running Labview 6.1, base dev. Do I need full dev for this?
-Fong
(3,070 Views)
Looks like you would need the full dev for these headers and lib's. Would explain why you dont have the cintools folder.
Bilal
Bilal Durrani
NI
(3,070 Views)
