Problem with Clear Graph in Mixed Signal Graph
I plotted a Mixed Signal graph in which both analog waveforms & digital waveforms are present.
When I clear the graph, the plot legend for the first digital waveform is visible always. It is not cleared from the graph.
Even when i close the vi & open that again, still the digital waveform plot legend is visible.
Any solution for this?
Labview 8.2(Windows Xp)
Raja
Message Edited by Rajaa on 10-07-2008 01:53 AM
Message 1 of 10
(5,629 Views)
you can do your own dialog box, and use the property nodes for doing what you wants...
I don't know if im clear... lol
Let me know if it helps you. I can send you an exemple.
V-F
Message 2 of 10
(5,602 Views)
Actually I don't understand what you mentioned. I want to clear the graph including the plot legend(Mixed signal graph). See the attached image in my previous post.
Raja
Message 3 of 10
(5,593 Views)
i joined an exemple in labiew 8.5
hope it helps you.
let me know.
V-F
Message 4 of 10
(5,583 Views)
The VI in Labview 8.2...
V-F
Message 5 of 10
(5,582 Views)
Your Vi shows broken arrow. Some property is missing in the property node. That may be due to version(8.2) problem.
But actually, the problem is in "Mixed Signal Graph". When I clear the graph, one of the digital plot legend is visible in the graph.
For reference see the attached image.
Raja
Message 6 of 10
(5,579 Views)
Hey,
i joined the vi for the 8.0 version. but it should work with a 8.2 ! maybe is it because my Labview is a French version ??
Best regards
V-F
Message 7 of 10
(5,561 Views)
Your Vi still shows broken arrow. I think the property is not in Labview 8.2 version.
I have attached the screen shot.
But Actually, the problem is in "Mixed Signal Graph"  as I mentioned in the previous post. In your vi, Waveform Graph is used.
Raja.
Message 8 of 10
(5,552 Views)
Ok, and now, does it works ?
V-F
Message 9 of 10
(5,542 Views)
Thanks for your reply.
The vi works but When I Plot both Analog & Digital Waveform in the Mixed Signal Graph, the Plot Legend for the Digital Waveform is not cleared when "Clear Graph" is given in the right click shorcut menu.
I  have attached a sample vi in which Analog plots are in Group 0 & Digital plots are in Group 1.
The plot legend in Group 1 is not cleared. When I close & open the vi, still the plot legend alone is visible.
Raja
Message 10 of 10
(5,536 Views)
