Problem with Cluster
Please Why  can I Choose element Data of my Cluster.
See in the picture below
(3,464 Views)
I don't understand your question.  You are asking "why" you can choose something.  What exactly do you mean?
(3,458 Views)
Sorry,
it's :
Why I can't choose element Datas of my Cluster ?
(3,450 Views)
Accepted by topic author Fred19ni
Ahhh.  Completely different message.
If you have a wire with data that does not have a label and bundle it into a cluster, you can access it by the regular unbundle, but cannot unbundle it by name because it doesn't have a name.  The solution is to give it a name.
Two ways to do it.  Use a typecast on the brown wire to typecast it to the same type, but using a constant that has a name in its label.  The other is to wire a cluster constant into the top of the unbundle and make sure all the elements in that cluster have a name in their label.
(3,445 Views)
