Problem with Com port
@inuyasha84 wrote:
I have already installed them as I have written before they should support the W7.
the problem is elsewhere.
Is it possible that the visa control see the port (when I click refresh the port is there) but can't open it?
No,  If VISA and MAX see the COM port an I/O session can be opened.  Check the port settings.  If the settings conflict with what the device on the other end expect data transfer won't happen.
What's the device? Does you code give you any warnings or errors when you run it? (if so what error?) post a snipette of the malfuntioning code.
Message 11 of 13
(905 Views)
@inuyasha84 wrote:
 I get the error like ......
Exactly what error do yout get?  Error number? exact message?
Message 12 of 13
(903 Views)
hi guys. sorry for the delay. yesterday  thanks to a COM arbiter I have disabled them all and I have uninstalled the com driver and installed again. Doing this The com passed to be named COM25 to COM3 and now works fine.
Unfortunately I can't tell you the error that I got because I manage the error changing the code and the message
Message 13 of 13
(881 Views)
