Problem with Data acquisition in a VI which is displayed as a Pop-Up
Hello All,
I am trying to acquire data from Futek Load Cell via Futek Amplifer which will give a scaled output of -10 Volts to +10 volts. I am using cDAQ 9174 and NI 9205 AI card for this acquisiton.
I have coded a LabVIEW program to acquire this as attached which is working fine if i run this application.
The problem i am facing when i call this VI as Pop-Up where i could see the data only once.
Can you please tell me where i am going wrong and help me in that?
SrikrishnaNF
Srikrishna
(2,910 Views)
Greetings! First things first, please attach full code or a useable snippet, not a screenshot, it's harder to poke at code we can't interact with. Second, I see you have a generate tone, which will hog loop execution and won't allow code to further progress until it's done, which might not be optimal. Second, if the VI is a dialog, it will only take what the read function feeds it for the first task, and won't further update; instead, feed it the task as an input, and have a read function inside the dialog VI so it constantly updates with new info.
(2,889 Views)
