Problem with File Dialog VI when built
Hi
I'm building an application which use File Dialog.vi. When I run my application with LabVIEW, everything works perfectly. When I build my application, and I run the .exe,  I get the following error: Error 7 occured at Open File+.vi:Open file. I don't know if any of you might have an idea of what is the problem.
File Dialog.vi Selection Mode is set to Files or Folders and New or Existing
I'm using LabVIEW 8.0.1
(2,994 Views)
This is a common problem when building Apps.  Check out this thread:
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,964 Views)
Thanks for your reply
I guess I wasn't looking for the good thing...
Thanks again
(2,959 Views)
