Problem with Keyboard using a USB bar code scanner
             Hi all.
             I'm having a problem.  I'm using a USB scanner (LS2208 Symbol).  I get the data from the scanner on a control but
             can't detect the "enter".   A second issue is that, using the numeric keypad  I can detect the "enter" but I if press
             the  "enter" on the alphabetic keypad doesn't work either the scanner.
             The VI is looping until the string read from the scanner and count the string = 5 then  stops.
             I already try programing the scanner with the carriage return and enter but doen't work.
             Some suggestions.
              Reynaldo Lima V.
              Test Software Engineer
              see the attach VI
Ing. Reynaldo Lima Villarreal
Ingenieria Electronica (I N G E L)
Reynosa, Tamps. México
Cel: +52 899 160-52-59
Email: reynaldolima@aol.com
(3,833 Views)
Go to Tools>Options>Front Panel and check the box called 'End text entry with Enter Key'.
Also, don't post VIs that are set to run when opened and have the toolbar hidden.
(3,814 Views)
Here is a vi that I use with a Symbol LS3408 USB scanner. 7.0 format
(3,795 Views)
         Hi Dennis.
         Thanks for your support,  I already did the changes on the tools options.   I got the probles fix.
          Thanks.
(3,780 Views)
