Problem with LV aplication on Win 7
Hello
I programmed a LV application in OS Windows XP, and the application work perfectly.
But I have a problem with functioning of the application in OS Windows 7.
Application freezes, and is slower response.
Is there any allowance for the same operation, or something??
Please help me.
Greetings
X_man
(3,374 Views)
What version of LabVIEW are you using. Can you post the code to this forum?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,345 Views)
LV 8.6
(3,343 Views)
Is the application in the form of an exe or are you running it in the LabVIEW development environment under Win7?
Putnam
LabVIEW Champion
(3,339 Views)
The application is in the form of an exe.
I thing I have the problem with events, but i don't know why.
(3,337 Views)
First, be aware that LabVIEW 8.6 is not officially supported under Windows 7. It might work. It might not. Second, you haven't told us what the application does, or shown us any code, so we all we can do is play guessing games. I personally don't feel like doing that. So please help us help you by providing some details as to what your application does, instead of saying "application freezes, and is slower response". What does your application do? Does it use hardware? Does it use toolkits? Is it running on 32-bit or 64-bit OS? Have you verified that any additional software, such as hardware drivers and toolkits, are compatible with your version of Windows 7?
What kind of troubleshooting have you done?
(3,318 Views)
