Problem with LabVIEW Run Time communicating with Access Database
I created a VI that communicate with an Access Database. When I run my VI with LabVIEW 7.1, i have no problem. Then I created a .exe and when I try it on a PC with LabVIEW Run Time 7.1 and Access 2000 RunTime, I have the error "-2147319779" Library not registered, anybody can help me?
(3,515 Views)
Bonjour,
Si vous utilisez le "Database Connectivity Toolkit" de LabVIEW 7.1, les documents joints vous aideront à troubleshooter votre problème:
* Building Stand-Alone Executables With Database Connectivity Toolkit VIs
http://digital.ni.com/public.nsf/websearch/FCCCBC6B519CEC2E86256C95007E8FA9?OpenDocument
* Creating an Executable Using SQL Toolkit VIs
http://zone.ni.com/devzone/conceptd.nsf/webmain/909F5706CE255C1C86256802007B8D2A
* Creating an Executable with the LabVIEW SQL Toolkit
http://digital.ni.com/public.nsf/websearch/472FBF6376153553862565DF004DED20?OpenDocument
Cordialement.
Matthieu G.
(3,501 Views)
