Problem with Loop foor with register shift
I have try the new vi, but now the 2 array doesn't work
I have try to put out the final while loop and I have the same problem
Is it due to the register shift ?
Message 11 of 15
(1,023 Views)
Hi mini...,
as before just an initialization problem of the outer SR...
Maybe you have to change the init scheme to the one used in the inner while loop as now the SR will be reset with each call of the vi.
Message Edited by GerdW on 04-08-2008 10:27 AM
Message 12 of 15
(1,019 Views)
Excuse me, but I don't really understand what you want to say ?
Message 13 of 15
(1,008 Views)
Hi Mini...,
I added an initialization step for the outer SR (and deleted unused code), now the example should work...
This init step will be called everytime the vi starts as it is connected with the iteration counter. When this is not what you need you can change the initialization to using the same scheme as the inner while loop: a SR holds the status (init/not init)...
Message 14 of 15
(1,002 Views)
Hi, I have try the new program and it works wery well
big thanks
I have import all  in my big program ans it works very very well
Message 15 of 15
(989 Views)
