Problem with LvVariant.cpp on line 696.
I recieved this error and LabVIEW crashed when attempting to connect to a running VI using AppletVIEW. What is causing this and how is it fixed? I am using LabVIEW 6.1 on Windows XP with the (very) latest version of AppletVIEW 3.0.3
(2,886 Views)
esvaq;
You can check (i.e., search) internal errors at the following page:
http://www.ni.com/support/failure/
Apparently, the specific internal error you are mentioning is not documented in NI Knowledge base. Check the NI document LabVIEW Internal Errors which is a general guide to troubleshoot internal errors.
The other option is to contact Nacimiento Software Corporation, the creators of AppletVIEW. In their website they have a FAQ which includes error information related to LvVa
riant.cpp. Check if the solution applies to you. Otherwise, they provide support to their product.
Regards;
Enrique Vargas
www.visecurity.com
www.vartortech.com
(2,886 Views)
