Problem with .NET FolderBrowserDialog
I try to use the FolderBrowserDialog from the .NET Framework. While the OpenFileDialog works as it should, the FolderBrowserDialog does not show any content except the buttons OK and Cancel. It works if I use it in other languages like C#.
I created a constructor node and invoked the show method. That's all. I also tried to set the properties first (root dir, etc.) but didn't help.
Any suggestions?
Thanks in advance,
Alex.
(6,414 Views)
Try running your VI on the User Interface Thread.
[File >> VI Properties >> Execution; Preferred Execution System: user interface]
George Erwin-Grotsky
LabVIEW Research & Development
(6,404 Views)
that worked.
thanks,
alex.
(6,399 Views)
