Problem with NI 6221
Hi. I use one analog output channel and 5 input channels. They all are scanned. When I work only with one output and input chanels (4 channels are not connected), I can see on them the same signal as on working channel.
I read the following issues:
http://digital.ni.com/public.nsf/websearch/B9BCDFD960C06B9186256A37007490CD?OpenDocument
http://digital.ni.com/public.nsf/websearch/4E9B8B3F8FD3A31B862562B5004EA1D9?OpenDocument
I want to understand, what are the solutions of my problem?
What is the source impedance - выходное сопротивление источника?
Thank You.
Message 1 of 9
(5,218 Views)
I forgot. I use RSE (not differential inputs). How are they connected in NI 6221?
May be I have to connect the second input from two to ground?
Message 2 of 9
(5,217 Views)
This is normal behaviour. The 6221 has a multiplexer witch switches the input channels of the AD converter.
A residual voltage will be present at a floating input.
Ground non-connected inputs and you will be OK
Ton
My LabVIEW Ideas
Message 3 of 9
(5,214 Views)
You mean, that I have to connect with ground other 11 input channels. (5 channels are connected allways and I work with them all but sometimes I work only with one or two channels)
Message 4 of 9
(5,210 Views)
Floating inputs are bad inputs!
But I usually only ground the first floating input, that will do most of the time.
Ton
My LabVIEW Ideas
Message 5 of 9
(5,208 Views)
The decision is not to use floating channels?
floating channel - sometimes connected channel, sometimes disconnected?
Message 6 of 9
(5,198 Views)
A floating channel is a channel that is not connected, just ground it when you pull of the signal.
Ton
My LabVIEW Ideas
Message 7 of 9
(5,194 Views)
Are these floating channels set in the scanning list?
Message 8 of 9
(5,171 Views)
No, I mean phisical, if you remove the wire from your connection board, you have a floating input, connect this input to the ground via a terminator or something.
That is enough.
Ton
My LabVIEW Ideas
Message 9 of 9
(5,169 Views)
