Problem with NaN treatment in LabView 2016
I have a camera program in which I use many IMAQ functions. By the error out output of these functions, if Status is set to False, the measurement run without error. In this case, the program displays the measured value. However, in the event of an error, I would like the program to return a NaN value.
I can generate Nan value in two ways: "zero divided by zero" or "square root of -1".
In the former case, the program works well and displays a "NaN" value. In the latter case, the program always returns 0 value. Why doesn't this case work?
Message 1 of 11
(2,929 Views)
You can just type "nan" (case insensitive) into a DBL constant/control.
(It would help to see some simplified code, especially the non-working case. For example sqrt(-1) is NOT NaN if the input is complex)
Message 2 of 11
(2,925 Views)
Hi sziszkont,
Well, there is (atleast) a 3rd way: simply use a "NaN" float numeric constant!
Why do you need a (quite senseless) calculation to create a NaN value?
It seems you doing something wrong when calculating sqrt(-1):
Message 3 of 11
(2,920 Views)
Could you help me with what could be wrong?
Message 4 of 11
(2,889 Views)
Note that while "zero divided by zero" is always not a number, "square root of -1" may or may not be a number depending on the type of numeric representation.
Message 5 of 11
(2,888 Views)
We can't debug a picture.
Also... it looks like your -1 isn't wired to the Sqrt function?
Also also, get rid of the sqrt function altogether, and type "nan" into the inside of the orange box. You've got it typed into the label of the orange box.
Message 6 of 11
(2,883 Views)
Hi sziszkont,
  • missing wire at "-1" to sqrt function
  • labelling the "-1" constant as "NaN" instead of typing the value of "NaN"
  • lots of coercion dots
  • Do you really need SGL values? Really? Why not stick with DBL values avoiding several additional type conversions?
  • missing comment in the subdiagram label of the case structure
  • Do you really need to output NaN? Would it make sense to output the previous values in case of an error?
Message 7 of 11
(2,864 Views)
Something has to be wired to the input of the Square Root function since it is required.
Message 8 of 11
(2,853 Views)
It is -1 wired to the Sqrt function, only not shown in the picture.
This has been a well-functioning program for years, but now I ran into this bug that returns 0 instead of NaN. I'm looking for an explanation for this. If I use 0/0, the error is solved, but why?
Message 9 of 11
(2,794 Views)
You have been told already that pictures can NOT be debugged. So post your actual code if you want us to help you further than this!
And no we do not ask you to post your company top secret VI that spans 20 screens across. We would actually appreciate it if you can create a small test VI that shows the effect that you claim you see. In many cases while creating that test VI you will often already see yourself where the real problem is!
Rolf Kalbermatter  My Blog
Message 10 of 11
(2,790 Views)
