Problem with PWM signal + analog input together !
Hi everyone,
I have attached a very simple VI where I want to :
 1°) acquire a 50 hz PWM signal (I have used one of the Labview examples) to get a value once per second
 2°) acquire 1 analog voltage : 100 samples at a rate of 1KHz every second and then make an average
These to things work fine on their own ! However when I create this VI it works fine for a few seconds and then I get a failure message. I then need to "initialize" the Daq-pad with MAX.
Would anybody know what the pb is and how I can get them to work together? Ideally I would need to measure another PWM signal.Once again I succeed in measuring two pwm signals (with ctr0 and ctr1) but not with the analog signal at the same time.
Am I doing something wrong or is it just perhaps not possible with this card?
Any help would be great,
I am using windows XP, Labview 8.0 and a DAQ-PAD 6015
Marc
Message 1 of 10
(3,992 Views)
Hey Marc.
Could you attach a screenshot of your failure message please? It should be helpful.
Best Regards.
Romain D.
National Instruments France
Message 2 of 10
(3,967 Views)
Hi Romain,
Thanks for your help. Here is a screen shot of the message. We can go on in French if you want ( I am French).
Best reagards,
Marc
Message 3 of 10
(3,956 Views)
PS : my screen shot gets clear to read if it saved on the computer and then opened..
Message 4 of 10
(3,953 Views)
Hello Marc,
Typically this error is caused by the absence of a clock when performing timed operations.  For example, if you set up a task with an external clock, but then fail to connect the clock signal.  The board will wait and then timeout when it does not see any incoming clock edges.
You are simply performing a test panel, and therefore the clock should be internal to the device.  This may indicate a damaged counter system on your board. We provide a utility to test your card to verify that each of its subsystems are working.  I recommend running the DAQ Diagnostic Utility (DAQmx 7.5 or newer) or E-Series Diagnostic (Traditional/Legacy DAQ) and if possible, testing the card in a second system to verify that the problem lies with the card. If you find the card fails, please request support at ni.com/support to initiate a repair.
Regards.
Message Edité par R_Duval le 01-10-2008 09:31 AM
Romain D.
Message 5 of 10
(3,945 Views)
Hi Romain,
I have tried the DAQ Diagnostic Utility (I have attached the log file) but all the tests are ok. I have tried with another computer but the same fail message appears... the device works fine according to the test result (and according to MAX or when I do these measurements seperatly) so I guess there is something wrong in my program?
If you have another idea...
regards,
Marc
Message 6 of 10
(3,911 Views)
Hi Marc.
In fact, we know that your card is ok Smiley Wink.
"Typically this error is caused by the absence of a clock when performing timed operations.  For example, if you set up a task with an external clock, but then fail to connect the clock signal.  The board will wait and then timeout when it does not see any incoming clock edges."
Do you use an external clock?
or configure anything with it?
Romain D.
Message 7 of 10
(3,897 Views)
No I am not using any external clock. I am just running the VI I have posted... so from what I have understood, I am only using internel clocks for the analog input and the PWM signal.  Have you been able to run my VI?
Marc
Message 8 of 10
(3,895 Views)
Yeah, I have already run your VI. I hadn't your problem.
You could reinstall the drivers, but i advice to desinstall them before.
You can dowload the drivers here : https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
Romain D.
Message 9 of 10
(3,890 Views)
Hi Romain,
Well I had infact already reinstalled Labview 8.0 + the drivers a week ago....
I think I'll just have to acquire my two PWM signals throughLabview and use another solution to measure the analog voltage on its own.
Thank you very much for your help anyway,
Marc
Message 10 of 10
(3,861 Views)
