Problem with Plot multi xy .
In the below code i want to display x axis as time scale according to my application .
here when i have only 1hour readings i am able to manage correctly
When i have more than 1 hour reading it is displaying as 0.00 to 0.99 . As i am doing with respect to time scale i want to display only till 0.00 to 0.59 is this possible .
(3,030 Views)
Hi Nagaa,
It is possible to display 0.00 to 0.59 by using Saclling Factor (Multiplier and offset) of the x axis
Santhosh M
(3,017 Views)
thank you sir
Sir can i know how can i do Saclling Factor (Multiplier and offset)
If you dont mind can i have full explaination please
(3,013 Views)
