Problem with Polymorphic VI with only the output types changing.
I have build a Polymorphic VI but the only type that changes from one instance to the other is the outputs. The inputs are the same in each instance. But when I try to wired the different output type if it's not the default type the wire is broken. I have to right-click, chose Select Type and choose the instance that I want. But I want the VI to do this automatically depending on the output I wired....Is this possible or the instance of the VI is chosen on the inputs type only.
(2,658 Views)
Hi Gilles,
the instance of your vi doesn't know what type of data you need after call.
Between nearer datatypes LabVIEW creates automatically a cast to the new
type (like I32->I8), but when you have incompatible data no cast could be
created. Therefor you have to select the type of the used instance for
yourself.
Henrik
GillesHache schrieb in im Newsbeitrag:
506500000008000000C8200000-991728092000@quiq.com...
I want the VI to
(2,658 Views)
