Problem with Read JPEG File.vi and localized chars on MacOS
A simple but nasty bug (LabVIEW 7.x and 8.x on Macintosh) : Localized characters (é è à...) are not accepted by the Read JPEG File vi.
No problem with other file vis. No problem on PCs.
Chilly Charly    (aka CC)
(3,228 Views)
And the workaround would be to write a wrapper which would create a temporary copy of the file if it has any of those characters and then read and delete the copy. Of course, if the same happens with a save, then you would have to create it and then rename.
___________________
Try to take over the world!
(3,218 Views)
This was reported to R&D (CAR # 42C1UR18) for further investigation.
Roy
(3,171 Views)
