Problem with Rec Get Value From Field.vi
I have noticed a problem with an application that uses the database toolset.  The application typically runs fine, but after 2-3 of operation the PC slows down.  Using the performance monitor with XP, I found out that the CPU usage goes up to 100% when this slowdown occurs, and it is due to LabView.  Using the LabView profiler, I found out that the offending vi appears to be "Rec Get Value From Field.vi".  Is this a known problem?  Is there a fix for it?  Thank you.
Message 1 of 1
(2,559 Views)
