Problem with Savinsky-Golay ptbypt.vi in labVIEW 7
Hi
I am having a problem with the Savinsky-Golay ptbypt vi in labView 7.  It does not  appear to smooth data as expected.
I attach an example vi I am put together which demonstrates the problem.  The data is reversed in sign, greatly reduced in amplitude and is not smoothed at all.
I have used this filter in Microcal Origin and found it to work very well on my data.  The LabVIEW vi requests the same input paramers i.e. smooth window nR=(-nL)and ploynomial order.  I can only think there is a bug in the vi.  Has anybody elce encountered this problem?
Many thanks
Ash
(2,688 Views)
Hi Ashley,
you initialize the filter on each data point, just remove the true constant. The VI itself will do the initilization (with a firstcall? node)
Then the data looks good.
Ton
My LabVIEW Ideas
(2,684 Views)
Hi Ton
Removing the true constant does indeed ensure the data is smoothed.
However I am seeing a phase shift proportional to the width of the filter window which moves the position of my peak.  When I run the same S-G filter in Microcal Origin this phase shift does not occur.
Is there something elce I have missed?
Many thanks
Ash
(2,681 Views)
Needed to edit the array to remove phase shift.
(Could oversample to compensate for data  points lost)
See vi attached.
Works nicely.
Ash
(2,657 Views)
