Problem with TDMS in Matlab
Hi B.Wagner,
The "Read_TDMData.m" example was written and tested with versions R2007a, R2007b, and R2008a.  These versions are capable of handling libpointer strings and strings somewhat interchangeably, which I do not believe version R14 does as well.  If you try replacing 'DDC_FILE_NAME' with 'DDC_FILE_NAME.Value', then this line should execute properly.  I cannot guarantee that the two examples provided will work as expected with anything earlier than R2007a, since I haven't tested them with those earlier versions, so please let me know if you encounter any other issues or if the above solution doesn't work.
Chris M
Message 11 of 18
(2,616 Views)
Hi Chris M.
Thanks fot the fast help.
  I don't encounter the error anymore after I expanded all the DDC_FILE_xx expressions (thus Name, Description, Title, Author and Datetime) by the '.Value' term. The only thing that astonishes me a bit is that there's not a single outpout. The program simply runs, finishes and leaves me a blank screen. Is the example made like this on purpose (no title, date or graph for the values) or is it another incompatibility with my system?
B.Wagner
Message 12 of 18
(2,598 Views)
Hi Chris M.,
after working on a different project I returned to my tdms-Stream. As I wrote in my last message the inital error when using the 'ReadTDMData'-example disappeared after I made the changes you proposed. I didn't worry much about the blank screen when testing the routine with the 'SineData.tdm' file since I blamed my older Matlab-version for it.
Lately I perfomed a test with one of my proper .tdms recordings (see file attached) and I get the following error message right after loading the file:
>> ??? error using ==> calllib
>> Array must be numeric or logical or a pointer to one.
>> Error in ==> Read_TDMData at 43
>>    calllib('nilibddc','DDC_GetFileProperty',pfile.Value,DDC_FILE_NAME.Value,pfilename,pfilenamelen.Value+1);
Is there an error in my recording or is it again a problem with my Matlab Version??
greetings
B.Wagner
Message 13 of 18
(2,504 Views)
Hi B.Wagner,
It looks like the file you attached is a .lvm file, not a TDM or TDMS file.  Is that what you are reading from?  Do you have a .tdm or .tdms file you can post that gives the same error?
Jennifer R.
Message 14 of 18
(2,486 Views)
Hi Jennifer R. Oops...looks like I attached the wrong file....sorry for that...here's the tdms.... Greetings B.Wagner
Message 15 of 18
(2,463 Views)
Hi B.Wagner,
I was able to read the file in Excel, using the TDM Excel Add-In, so the data seems to have been logged correctly.
Jennifer R.
Message 16 of 18
(2,430 Views)
I wasn't aware of this, but NI has included an example in Matlab to write TDM files. I just tried it out and it works perfectly.
Thanks a lot!
Message 17 of 18
(2,424 Views)
Hi Jennifer R., O.K....so it appears to be a problem with my 'ancient' Matlab version 😕 . I'll try to get a newer one. Thanks for the help! B.Wagner
Message 18 of 18
(2,416 Views)
