Problem with UFF 58
Hi.
I'm trying to perform a modal analysis from the frequency reponse function obtained with the Impact Test with Software Trigger (DAQmx) VI (http://zone.ni.com/devzone/cda/epd/p/id/3438). I need to write this data into a UFF 58 file and I used the write_to _uff58.vi present in the Sound and Vibration Toolkit. However, there seems to be a problem because I got a uff file in UFF 58b (binary) and I need this in UFF 58 (ASCII).
Find here attached the VI's I'm using. How can I write this in UFF 58 (ASCII).
Cheers,
Adrian R.
(3,875 Views)
Writing to UFF 58 ASCII is currently not supported. Please, take 5 minutes to fill in a Product Suggestion Request:
http://digital.ni.com/applications/psc.nsf/default?openform
From NI, we take our customers requests very seriously. Also, be aware of next LabVIEW 2010 release in early August since the S&V Toolkit might already implement writing to UFF 58 ASCII.
Best regards.
(3,860 Views)
I also would like to write in an ASCII UFF Format.
Is this already integrated in Labview 2010 or 2011??
Until know I couldnt find it...
Thanks for answering,
Frank
(3,689 Views)
