Problem with VI properties
After creating a vi i changed its properties and un checked options of winodws menus etc. Now VI starts and i have no option to stop it or modify it at all. Is there any solution to get back to the properties options.
immi
(3,128 Views)
If debugging is still enabled try Strg-.
Long way: write a vi with vi-server vis: open a reverence to the vi and stop it
Greetings from Germany
Henrik
LV since v3.1
(3,121 Views)
Hi
Try this old trick: Open a blank vi. Insert your vi . Now, you can open it in edit mode.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,119 Views)
Thanks to both of you for reply it worked very well. However I tried another non-professional trick too to get it back to edit mode by removeing  one of the sub-vi i had in the same folder which consequently generated errors forcing it to go into edit mode.
ciao
(3,113 Views)
