Problem with VISA Configure Serial Port
Im am using the VI VISA Configure Serial Port to configure my COM-interface. However, I recognized that this VI sends a constant logic "0" signal for a certain duration over the COM when it is run.
This signal disorganizes the receiver at the other side of the line and I need to stop it, otherwise the communication does not work properly.
How can I do this?
Gerald
(2,716 Views)
Hi!
This VI sends no value. Inside it is only a proberty node which sets the new settings to your hardware. If you setting up other setting by any other software you will have the same problem with your hardware.
Regards Tobias
(2,681 Views)
