Problem with VISA Configure Serial Port
I have a probem! I need to send data via RS232. I'm using VISA resource. There is a pin, named 'termination char' in VISA module 'Configure Serial Port'. I don't need any chars, that terminates data stream(it can be value from 0 to 255 in data stream). How can I prevent VISA from checking that termination char??? Thank You!
(2,849 Views)
Hi Dron
Right Next to the terminal which says "termination character" is the terminal which says "Enable Termination Character(T)" By default this is true. You Just wire a False and Serial Device will be configured to to not recognize any char. as termination charaters.
Good Luck!!
Mache
Good Luck!
Mache
(2,849 Views)
