Problem with Waveform Chart X scale
Hi guys.
I am new here and Labview, sorry for my english wrongs. I am from Brazil.
So, i try have an absolute time in x scale, from my waveform chart, but the VI don't execute this. I wish make like the picture in annex. It´s the only problem in my project.
I Use Labview 8.6 version.
Please help me :D
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 1 of 48
(5,769 Views)
What is the datatype of the chart data?
What is the formatting of the x-axis?
You show us how it should look like, but you did not show us what you actually see instead and what the problem is. This missing information might give a clue on what's wrong. Easiest would be if you could attach the actual VI.
Message 2 of 48
(5,756 Views)
Hi friend,
             Its not clear what is posing problem. I am attaching one example VI. Let me know if this helps
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 3 of 48
(5,751 Views)
Hi
The datatype is 14 channel with single precision, and the format of the x-axis is absolute time, but, the VI don´t show it. And i wish to show divisions on each 5 min.
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 4 of 48
(5,749 Views)
Hi Ranjeet_Singh
can you send your VI in version 8.6???
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 5 of 48
(5,748 Views)
This is a print of block diagram with a close in waveform chart.
Icaro Kossmann
LabVIEW 8.6 Newbie.
Brazil
Message 6 of 48
(5,743 Views)
Here it is.
--Ranjeet
Message 7 of 48
(5,736 Views)
Your chart does not get any timing information, thus you need to set the dt manually or with a property node according to the update rate of your code (we cannot tell from the picture).
If you want absolute time, you also need to set the t0 according to the start time of the chart. Then you also need to select the desired time format of the axis.
(It really does not help to show us code pictures. I recommend you attach the actual VI.)
Instead of telling us what it does not show, tell us what is shows instead and what's wrong with it.
Message 8 of 48
(5,734 Views)
@Ranjeet_Singh wrote:
Here it is.
This is not really applicable, because you are showing an XY graph while the question is about a waveform chart.
Message 9 of 48
(5,725 Views)
Sorry I posted the wrong VI.
Here it is in 8.6
--Ranjeet
Message 10 of 48
(5,721 Views)
