Problem with WinCE
Hi guys,
I have a problem in developing a program for WinCE module and I dont really know where to find a solution. Basically it is a project with ca. 240 event cases, ca. 220 states (state-machine) with pretty much locals and globals variables.
When I compile the project to build an .exe file, I got this error message (in attachment) and I dont know where to find the solution.
This problem occurs when I try to expand a state with putting more locals/globals variables in a state.
Is there any limitation for bus-system (for local/global variables), maybe limit of numbers of variables in a state?
Any help would be really apprecited.
Yan
(3,004 Views)
Hi Yan,
I have never seen an Build Error Log from LabVIEW like you attached to your first post.
Which modules do you use? Which kind of code (LV Exe, C Code, ...) du you try to create? I don't know a module which is called WinCE module ...
Regards, Stephan
(2,962 Views)
Hi Stephan,thanks for comments.
here we have:
Touchpanel module.
LabView 2010.
We are trying to create an LV Exe to program a single board computer SBC600X which runs WinCE 5.0
The problem is, last friday I could compile the exe from the project, (save the project with the date as backup).
Then yesterday, I modified the project a bit, tried to compile, failed (received this error).
Then I decided to delete my modification from yesterday (monday), then compile again the project from friday (nothings changed), weird, I got the similar error. I tried to find help for such error, and I got only this, but I couldnt solve my situation from there.
regards,
Yan.
(2,956 Views)
