Problem with Window appearance
I have builted my application in windows 7. I maded some front panel decorations also with help of rectangular boxs
its running correctly in windows 7 . But when i runned the same builted application in windows ( Xp 2 ) the front panel
objects like rectangular boxes are getting left shifted .
What might be the problem
(2,935 Views)
Is the screen sizes and resolutions the same?
Can you post screen shots?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,917 Views)
In the below screen shot labels are shifting towards left when i made my code to run in other computers
(2,907 Views)
I only see one picture, so I don't see a "before" and "after" pair to see the difference. Are you talking about a font issue? The fonts between Windows 7 and XP are different. This is a known issue (search the forum and you will see this issue with fonts has been asked many times), and it's an operating system issue, not a LabVIEW issue.If you use "Application Font" or "System Font", the text will look different between the two operating system. Select a font by name explicitly on a user interface panel.
If it's not a font issue, have you checked that the DPI settings are the same between the two computers? Sometimes people change the DPI settings to make things bigger on the screen.
(2,895 Views)
