Problem with XY graph
Hallo
I want to build a XY Graph ( Voltage vs. Current) . Is there anyway to build the Graph without using FOR Loop but only WHILE Loop.
The problem is when I use WHILE alone , I'll get just a point on my Graph .
to Understand what i mean plz take a look  on the attached LV
Thank you
Toni
(4,067 Views)
Hi dctoni,
i hope this example helps.
Mike
(4,063 Views)
Sure. Don't reset the express VI with every iteration. There is an input called reset on the Build XY Graph and the default is True. Just wire a false constant to it. The on-line help says that the default is False but if you right click on the input and select Create Constant, you get a True. If you opne the Express VI, you'll also see the True state as the default.
(4,062 Views)
thank you for your replay
I tried to do like  you told me but it dosn't work on my LV , I don't know where is the Problem
can you help me plz
Toni
(4,054 Views)
Hi Toni,
add a false constant to your express vi and then it works.
Mike
(4,051 Views)
Thank you guys
  it works Smiley Very Happy
(4,042 Views)
