Problem with a compiled program
I have a problem with a compiled program on labview 6i.
This program used a serial port (COM1 or COM2).
During the launching of the ".exe ", a fatal error occurs.
Here this error:
=> APPLICATION caused an invalid page fault in
=> module LVRT.DLL at 0167:30164426.
Can somebody help me?
Regards
Cedric
(2,923 Views)
Hi Elkos,
You did say if you were using VISA or the serial port VI's.
In both cases you must make sure you have the appropriate drivers. For the serial port VI's you need serpdrv. VISA has its own install.
Ben
(2,923 Views)
Cedric,
This problem was fixed in the LabVIEW 6.0.2 update. You can download this update (along with the updated runtime engine) from our website.
Good luck with your application, and have a pleasant day.
Sincerely,
Darren N.
NI Applications Engineer
(2,923 Views)
