Problem with acquiring signals with DAQ
I am trying to acquire a voltage signal using NI-USB DAQ 6008 without using DAQ assistant express vi but the vi is giving out error as shown in the attached image.
I just want to acquire the voltage signal .
Can someone help me out in solving the error so that I can get acquire the voltage using DAQ.
thanks.
(3,452 Views)
You need to set the sample mode to Continuous with the DAQmx Timing function.  You also shouldn't wire in the "samples per channel" on the DAQmx Timing when you use Continuous mode.  All you are doing is making your buffer really small and are opening yourself up to some interesting errors caused by buffer overflows.
(3,429 Views)
Hi crossrulz,
I tired the way you suggested but I still get error as shown in the attached image.
Can I know how to correct it.
thanks.
(3,389 Views)
Accepted by topic author GoviRe
Hello GoviRe,
Please turn off Highlight Execution. ("the yellow lamp" should be turned to off/"white" )
Your samples get overwritten, because you're forcing them to get overwritten by using Highlight Execution.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,368 Views)
Hello GoviRe,
Did it resolve the issue?
Kind Regards,
(3,343 Views)
Thanks for your suggestion now it is reading continuously without popping up any error.
(3,334 Views)
Thanks for the update!
Kind Regards,
(3,328 Views)
