Problem with basic FPGA program
I'm currently working on a sbRIO-9632, and I need to use more digital IO that the one available in the "write direct IO" VI located under the starter kit 2.0 section.
So I tried a really simple program to see if I could write on the IOs. Here are both my RT and my FPGA program:
And once I start the program, nothing happens. I'm not really sure how the different options in "open PFGA reference" work, and how I should deploy the FPGA program, that might be my problem ?
Thanks in advance for your help.
(3,686 Views)
Hi PLesur,
do you mind to attach a non-scaled version of your image?
(3,670 Views)
Yes, sorry if it was too small.
Here it is
(3,662 Views)
Hi PLesur,
- Did you start your FPGA VI after opening it's bitfile?
- You only output constant values to your FPGA  - thus the FPGA output will never change…
- You only transfer two values from RT to FPGA, but in the FPGA you have 4 controls. Increase your FPGAWriteControl node and select all 4 controls…
- Using AutoCleanup (Ctrl-U) on your RT VI will be VERY helpful…
(3,651 Views)
