Problem with biphasic signal generator
Hello!
I have filtered signal and detected envelope with OAT envelope detection.vi of given length. And now i need to modulate it with biphasic signal (picture). The biphasic signal should have same length as my envelope signal. I want to be able to change width of both peak(25us) and width of period, frequency(1 kHz), amplitude(1) of that biphasic signal. I know that i can start with pulse pattern.vi (check my scheme). But I dont know how to put it together it give me only one period. I have LabVIEW 2013.
(3,748 Views)
Accepted by topic author TomTomTomTomTom
You can repeat your signal pattern by means of a loop. Keep in mid that the number of times the pattern is repeted depends of th lenght of your message and the sampling frequency you are using for both the pattern and the message. Check this picture (just a quick suggestion):
Repeat pattern
best,
(3,714 Views)
Thank you for your answer. This forum is great!
(3,700 Views)
hi there is any way you could upload the code i tried to work with this one but my one is not
working thanks a lot
(3,380 Views)
