Problem with build Array
when I am trying to save my capacitor values into a file, they are storing as 0. But LCR meter is reading values in pico farads. i m attaching my program. please suggest me necessary changes in my program
(4,115 Views)
Hi Guruva:
Could you upload your code in LabVIEW 8.0?
I think you have to change the indicator format. Because you read your value in pico farade.
(4,109 Views)
Hi Guruva,
change the format specifier of the Write-function to "%g"... And read the help for those format codes!
Message Edited by GerdW on 12-07-2009 04:03 PM
(4,108 Views)
By default, the format is %.3f in Write to spreadsheet file function. Change this to write pico values (in order of -12). This will solve. Post back.
(4,102 Views)
Or, if pF is the native format, it might be more meaningfult to multiply the value by 10^12 before writing.
Matt
(4,075 Views)
